Ability to reverse route in read only
So I’ve wanted to build a route like my Old-Style routes in layers which I ended up building two, one for inbound routes and one for outbound routes. Ideally I would build one and simply reverse route to be happy but the route is in read only. Is it possible to keep the route itself in read only while allowing the ability to reverse route?
I agree. The issue is really what needs to be hardened to disk? I could easily agree that the waypoints should be saved (and lockable) but the order of the route should not be.
In fact, when a route is selected I think you should be prompted as so the direction and which waypoint…
If there is a route a-b-c-d-e-f then the default waypoint would be the one that is closest to the boat and the default direction would be to the waypoint that is farthest away (a or f).
These should be verified, but it seems like a logical choice to me.
