This update fixes a number of issues, including one that prevented the current-based ETA calculations added in the last update from being used on new routes. However, the primary focus was on ensuring the apps would run for long periods of time without any performance degradation.
- Improved stability and memory usage over time
- Added the depth offset option to depth sensors
- Added the Route Monitor context menu options
- Use NMEA 2000 heartbeats when available for online/offline detection
- Fixed the True and Ground Wind digital instruments
- Fixed tips for items in old-style fleet background layers [rose-point-ecs-portal]
- Fixed a problem with recording voyage data
- Fixed a problem with deleting instruments by dragging them off the panel
- Fixed a problem where making changes to instrument panel options didn’t always work
- Fixed a problem where some chart symbols would not rotate with the chart then they should have
- Fixed a problem with AIS vessel name orientation when the chart is rotated
- Fixed a problem that prevented current stations from being assigned to route legs
