Boundary Circle Notifications at Startup
When starting the Beta, I receive a notification that we are leaving visible boundary circles I have defined with “Outside” as the off-limits zone. I use these extensively for anchorages and have a lot of them, so the notifications are numerous.
If I restart the Beta, I do not get all of the same warnings but just warnings for a subset of boundary circles, and with each restart I get fewer notices until eventually I seem to just get notices for boundary circles I am not inside but are in my immediate area (within a mile or two). I haven’t been able to confirm this yet, but I believe if I don’t have the Beta running and we move to a new anchorage and then I start the Beta, the notices start over again.
I think my preferred behavior would be to not notify on any Outside violations at startup, and then to only notify after startup if the vessel is either already inside a boundary circle, or moves into a boundary circle, with Outside as off-limits and then subsequently moves outside the boundary circle.
Not exactly on point, but I want to chime and say that boundary circles are one of my favorite “small” features of Coastal Explorer.
I have a layer with boundary circles on certain hazards and the ATONS for the channel back into my marina. Coming back in at night - super helpful to find the start of the channel on a dark night, and to be positonally aware of where I am in relation to hazards. Navigating after dark in my home waters, I turn on that layer.
We will look into changing the boundary alarms to mean “leaving” rather than just “outside”.
Just so you know, though, Coastal Explorer now has an anchor watch mode that you might find more useful than using boundary circles.
Thanks Brad, we are familiar with the Anchor Watch mode. Regarding the boundary circles, my use case is to proactively generate potential anchor site circles based on the depth and desired scope so I can figure out approximately where I can anchor based on the expected swing room. Having a point at which to drop anchor that we know provides adequate swing room really speeds up our anchoring process. And if the anchorage is poorly charted, the circle determines the area that I want to “survey” for uncharted obstacles before dropping anchor.
