The Engine RPM is being displayed at 0.25 RPM resolution. That is “correct” in the sense that the values on the N2K bus are in that unit and the value displayed is correct.
But that leads to (I think) needless/annoying over-precision on the display. I would suggest that we add a rounding value to the instrument’s configuration. Personally I would default this to 10RPM, but if you really want to maintain backward compatibility then 0.25RPM (no rounding). I would permit any value from 0.25 to 250 (defaulted to 10)
