Own Ship Disappears on Startup
I updated to the latest Beta and noticed the icon for my own ship disappears shortly after startup. On starting, my ship icon appears then disappears when the tracks are displayed. The ship location should be at the cluster of short tracks in the center of the screen.
On a different but possibly related note, I would love to be able to delete all these tracks without having to individually select each one. They were created by have auto track on with the boat in the slip for the last couple months.
This might help with the second question :thinking:
Thanks BUBBA, that worked great!
This is still happening with the latest 4.5 update and the deletion of all tracks. My ship briefly appears (with a black arrow in front of it… wind?) then disappears. There also seems to be a mouse click dead zone around the boat. For example, if I left click near where the boat is nothing happens. But if I click further away from the boat I get a pop-up. Weird.
We’re still trying to figure this out, but haven’t been able to get it to happen here.
Was this working for you before the last couple of betas? Does the icon come back eventually, or is it gone until you restart the app? How long does it take for the icon to disappear? The black arrow could be the wind indicator…do you have an anemometer hooked up to Coastal Explorer?
Now that you mention it, I recently hooked up a Raymarine RotaVecta wind instrument to the ITC-5 transducer converter. This caused an update to the converter, presumably to add wind output to NMEA2000. I recently disconnected the instrument as it was in a test setting but have not yet hooked it back up.
The ship icon displays then disappears very quickly. Before any AIS targets get displayed. I’ve watched for several minutes and it didn’t come back.
Here is the output from the ITC-5:
If you have Coastal Explorer v4 connected to your NMEA 2000 network, would you mind sending a file from it to support@rosepoint.com? The file is a recording of all of the data from your marine electronics devices which we can use to see if some device is causing this problem. You can get to it by entering $data in the search box in Coastal Explorer and pressing Enter. That will open up a File Explorer where you’ll find a file called Electronics.log which can be attached to an email.
Sent. Three MB of electronic goodness!
Not sure how helpful this is but I determined that the “no click” radius from the boat location is 250 feet. Inside that radius, no right or left click behavior but outside is fine.
I also tried turning off all the Own Ship display switches, like displaying wind, but no change in behavior.
Thanks for sending the file! Unfortunately, I played back the entire log and everything worked fine. I was really hoping I’d see the boat icon disappear so we could figure this out!
Would you mind trying another experiment? I can see that you have two position sensors available, a GPS and your AIS. Would you use the POSN sensor status panel to manually pick whichever one isn’t in use and see if the icon reappears? And if that doesn’t work, would you try using dead reckoning to see if that makes it appear? And finally, try right clicking and using Move Boat Here to see if that does.
I was also not able to reproduce the “dead zone”. Does this seem to be 250 feet at any chart scale? Does the dead zone persist when the boat icon is not visible?
I tried the suggestions without success. Could not get boat icon to reappear. Note the boat icon is only visible for a couple seconds when the app starts then disappears. The 250 foot dead zone does change with scale.
Next I uninstalled the app, deleted the AppData beta folder then reinstalled. The boat icon stayed a bit longer but then disappeared as before. I installed missing charts to get rid of the warning but did not add the NGX gateway. No change after restarting.
The Application.log says the log level is set to info. You want me to run at debug level?
If you want to take a look yourself, I’d be happy to call into support so you can take control of the box.
That is the most detailed log level and I’m not sure what else to look at, but thanks for the offers! We are reviewing the code trying to find anything that could make this happen…so far we are completely stumped. Once the boat appears, it really shouldn’t go away!
If anyone else has had this happen, please let us know…
I think we might have this figured out… Do you have any “broken” range/bearing lines in any visible layers? Apparently there is a problem where a range/bearing line might not include two points. We’re not sure how that happens, but when it does they can prevent other things, including the boat, from getting drawn on top of the chart. A broken range/bearing line would show up with “N/A N/A” rather than the range and bearing in the list on the “Layers > Items” page. If you have any of these, removing them will hopefully restore your boat symbol. We have also fixed that problem for the next update.
Congrats, that was it! I had a handful of them. Deleted, restarted and everything looks good :waving_hand:
Excellent, thanks for your help! Do you happen to have any idea how those got created in the first place?
Looks like you can create them by opening CE4, then create a zero length line by just clicking in the same place twice, then open CE4.5. In CE4 they show as zero length, in CE4.5 then show NA.
Not sure how I originally created them but that works.
