I typically create routes by either forking an existing route and defining a new end point or creating a new route from scratch and defining both the start and end points. Either way, I then add waypoints by clicking on the route and dragging to the desired waypoint location, repeating until I have all the waypoints I need.
During this process I often want to reuse existing waypoints, and in the current version am able to drag the new waypoint over an existing waypoint and it snaps to the existing waypoint and inherits all of the properties (name, range, etc.) of the existing waypoint. In the beta, I can drag a new waypoint to an existing waypoint, and it does now snap to the existing waypoint (thanks for implementing that!), but the new waypoint does not inherit any of the properties of the existing waypoint. It would be very helpful if this inheritance functionality was implemented in the new version.
One other minor note on the beta implementation. I can create a new waypoint on a route by double-clicking on the route and dragging, but the snapping to an existing waypoint does not happen unless I drop the new waypoint and then grab it again and move it to the existing waypoint, whereupon it snaps to the existing waypoint as expected. Not a huge deal, but it makes a two-step process out of what is a one-step process in the current version.
