Broke my Installation w/ adding UDP
I was trying to simulate some NMEA sentences and setup the beta to look at 127.0.0.1 UDP port 10110 and after I set that option in the electronics menu it crashed the program.
Now every time I open the program it starts for roughly 2-3 seconds then closes. Is there a way to delete that configuration or do I need to reinstall?
LOG - some info redacted
[2026-06-08 08:39:56.097] [info] [Main Process] Platform: win32
[2026-06-08 08:39:56.099] [info] [Main Process] User data directory: C:\Users\xxxxxxxxxxxxxxxx\AppData\Roaming\Rose Point ECS (Beta)
[2026-06-08 08:39:56.099] [info] [Main Process] Main process VITE_APP_VARIANT: rose-point-ecs
[2026-06-08 08:39:56.121] [info] [Main Process] Renderer logging set up at log level ‘INFO’
[2026-06-08 08:39:56.127] [info] [Main Process] Loading window state from “C:\Users\xxxxxxxxxxxx\AppData\Roaming\Rose Point ECS (Beta)\mainWindow.json”
[2026-06-08 08:39:56.128] [info] [Main Process] wss listening on {“address”:“::”,“family”:“IPv6”,“port”:62784}
[2026-06-08 08:39:56.140] [info] [Main Process] {
“fullScreen”: false,
“maximized”: true,
“bounds”: {
“x”: 294,
“y”: 217,
“width”: 834,
“height”: 628
[2026-06-08 08:39:56.341] [info] [Renderer DEBUG] using 1536 as screen width
[2026-06-08 08:39:56.475] [info] [Renderer DEBUG] Setting renderer log level to info
[2026-06-08 08:39:56.476] [info] [Renderer INFO] Version: 4.5.0-260604204351.beta
[2026-06-08 08:39:56.476] [info] [Renderer INFO] Version date: 260604204351
[2026-06-08 08:39:56.477] [info] [Renderer INFO] Build commit: aa138908436b43dddc86971db8dcd857b3b36dd8
[2026-06-08 08:39:56.477] [info] [Renderer INFO] App variant: rose-point-ecs
[2026-06-08 08:39:56.477] [info] [Renderer INFO] App variant is locked: true
[2026-06-08 08:39:56.795] [info] [Renderer INFO] Electron product store is not yet implemented.
[2026-06-08 08:39:56.821] [info] [Main Process] Offline database located at: C:\Users\xxxxxxxxxxxxxxxx\AppData\Roaming\Rose Point ECS (Beta)\offlineRegion.db
[2026-06-08 08:39:56.823] [info] [Main Process] discoverer: loading gofree…
[2026-06-08 08:39:56.824] [info] [Main Process] GoFree: starting…
[2026-06-08 08:39:56.825] [info] [Main Process] discoverer: loading ssdp…
[2026-06-08 08:39:56.830] [info] [Main Process] Network: Ethernet 3 address xxxxxxxxxxxx
[2026-06-08 08:39:56.830] [info] [Main Process] M-SEARCH: Searching for urn:rosepointnav-com:service:nemo:1…
[2026-06-08 08:39:56.831] [error] [Main Process] ssdp: error: Error: bind EADDRINUSE 0.0.0.0:1900
[2026-06-08 08:39:56.833] [info] [Main Process] discoverer: loading mdns…
[2026-06-08 08:39:56.837] [info] [Main Process] Using Velopack update path: https://planz-updates.sfo3.cdn.digitaloceanspaces.com/velopack/rose-point-ecs
[2026-06-08 08:39:56.837] [info] [Main Process] Using Velopack update channel: windows-x64-preview
[2026-06-08 08:39:56.838] [info] [Main Process] Using Velopack update channel: windows-x64-preview
[2026-06-08 08:39:56.925] [info] [Main Process] udpGateway: 10110
[2026-06-08 08:39:56.928] [info] [Main Process] listening
[2026-06-08 08:39:57.416] [info] [Renderer WARN] fleet_settings: load: unsupported option: VDR_AIS
[2026-06-08 08:39:57.416] [info] [Renderer WARN] fleet_settings: load: unsupported option: VDR_AllNavigationData
[2026-06-08 08:39:57.831] [info] [Main Process] M-SEARCH: Done waiting on urn:rosepointnav-com:service:nemo:1 closing socket
[2026-06-08 08:39:58.539] [info] [Main Process] svc_events: record: {“time”:“2026-06-08T08:39:58.000-05:00”,“type”:“start_app”}
[2026-06-08 08:39:58.540] [info] [Main Process] trackingFileQueue: recording event…
[2026-06-08 08:39:58.542] [error] [Main Process] Uncaught exception: undefined TypeError: bufferUtil$1.unmask is not a function
at bufferUtil.exports.unmask (file:///C:/Users/xxxxxxxxxxxx/AppData/Local/com.rosepoint.ecs/current/resources/app.asar/index.mjs:2717:27)
at Receiver.getData (file:///C:/Users/xxxxxxxxxxxx/AppData/Local/com.rosepoint.ecs/current/resources/app.asar/index.mjs:3773:11)
at Receiver.startLoop (file:///C:/Users/xxxxxxxxxxx/AppData/Local/com.rosepoint.ecs/current/resources/app.asar/index.mjs:3521:18)
at Receiver._write (file:///C:/Users/xxxxxxxxxxx/AppData/Local/com.rosepoint.ecs/current/resources/app.asar/index.mjs:3459:12)
at writeOrBuffer (node:internal/streams/writable:570:12)
at _write (node:internal/streams/writable:499:10)
at Writable.write (node:internal/streams/writable:508:10)
at Socket.socketOnData (file:///C:/Users/xxxxxxxxxxxx/AppData/Local/com.rosepoint.ecs/current/resources/app.asar/index.mjs:5746:37)
at Socket.emit (node:events:509:28)
at addChunk (node:internal/streams/readable:563:12)
[2026-06-08 08:39:58.599] [info] [Main Process] trackingFileQueue: continuing file from previous session
Unfortunately there isn’t a way to remove the port other than with the UI or re-installing. However, this crash is only happening if data is received so if you can temporarily disable the sending program, you should be able to use the UI to remove the port.
We are working on a fix for this and I expect an update to go out later today.
I was able to reinstall and get it back going. Using “Add Remove Programs” feature did not work I had to delete the folder out of AppData and was able to get back going. Thank you.
We just released an update that fixes this problem.
What is the path to the folder that you removed? Removing AppData/Local/Rose\ Point\ Navigation\ Systems/ did not fix it for me.
Mine was “C:\Users\XXXXXXXX\AppData\Roaming\Rose Point ECS (Beta)”
