CMAP not installing
Hello, I have been trying to install CMAP maps and I keep getting errors. These are:
  1. The CMAP chart licensing has not been installed ….
I have installed the CMAP licensing system software and shows up in the software list.
  1. Its says the CMAP system is down for maintenance
Could you please let me know what I have done wrong.
The C-MAP store is in fact closed until they release their next update which we are told will be sometime this month.
However, the fact that you keep getting errors trying to install the C-MAP licensing system sounds like a problem. By any chance are you using an ARM-based PC? I don’t think C-MAP can work on one of those.
Hi, I am running windows 11 on a mac running parallels. I can try on a pc however at this time I am trying the demo version. Is there a way to reset the demo 10 day timeout so I can do testing before I purchase Rosepoint and charts.
That explains the problem with installing the C-MAP licensing system, Windows running under Parallels is not a supported configuration. The 10 day trial is per-device, so you should get another 10 days when you try it on your PC.
