Missing dead reckoning mode and virtual boat for what it’s worth.
It’s in there, but some if it is a little different… There is a new menu button on the chart tip that can be used to access the “Move Boat Here” option which will start DR mode. You can also select the “Dead Reckoning” option from the POSN sensor status menu. Once you are in DR mode, you can drag the boat around and use the Ctrl+Shift+Arrow Keys to adjust heading and speed. We’ve also added a “Settings > Electronics > Dead Reckoning” page you can use in DR mode to make finer adjustments.
Got it, was not seeing default formatting for heading colors and heading line style, track lines. Also ship properties missing vessel symbols and colors for vessel and predictor line.
Also noticing the route monitor moves the whole task pane information up or down not just the route information, looks to be missing the bar slider in the space for route monitor.
The route monitor scrolling problem has been fixed.
We will add the default formatting options soon and probably add some more options to it in the process.
We are not planning on adding vessel symbol options, but please let us know if you feel they are important! (In a new topic about just that would be great…)
