Is there a way to change the default arrival circle radius for newly created waypoints? 0.05nm is a bit much for my boat and cruising speed.
Thanks,
Zora
Thanks,
Zora
Right click on the waypoint, choose properties at the bottom of the pop up menu. Change the arrival circle radius to something you like.
Or, if you are asking about changing the default globally - sorry, no idea.
It’s the default 0.05nm I’d like to change. Some of my routes contain a couple hundred waypoints. Tedious it is to change the waypoints individually.
Agreed - There ought to be a way to make a change to the global default for that.
