Depth Finder Offset
The latest release indicates an option for Offset on Depth Sounders. I can’t find anywhere in the software to set this “adjustment”.
In Settings > Electronics, find the port your depth sounder is connected to, then click on it so you’re looking at the details of that single port.
There, under Sensor Settings, you should find “Depth Sounder.” Click it.
Now you should see a page that looks like this:
Amongst other things, this is where you can set the offset for that sounder.
I hope this helps!
