What is the procedure for terminating route placement given there is no right click or escape key on the iPad?
Tapping the last waypoint will finish a route. (You can either double tap to place the last waypoint, or just tap to place and then tap again to finish.)
I have e-mailed a video showing the route is cleared when I double tap or tap again.
I’m afraid we can’t reproduce this problem… Are you able to create other objects, like marks or range/bearing lines?
