I’ve used Coastal Explorer for a number of years and probably have 75 routes I’ve constructed along with specific marks I’ve added. I want to transfer this information to Coastal Explorer on a new laptop. Can I export these to a thumb drive and move them over and install them into the new version. Thank you
You shouldn’t have to use export, but that would be one way. The easiest way, if you want everything, is to just copy your voyage plan document (layer file) from the system that has that data, then use the thumb-drive to move it and copy it to the Documents folder on the new system.
Make a note of the name of the layer you want to copy, and the location on your hard-drive where it’s saved, so you can find it in Windows File Explorer.
Give us a call if you have problems with any of these steps.
425-605-0985
