I loose Chart data when I disconnect from WiFi. I have downloaded the region however I need to stay connected to WiFi to continue to see Chart Data.
Are you using the “Downloaded Charts” option on the Chart Type menu when you go offline? This will probably become automatic at some point, but for now it is necessary to manually switch to using the downloaded charts.
Brad,
Thanks for pointing out to “Use Downloaded Chart” data! I was unaware of this selection.
