When a new build is posted, will the iOS Coastal Explorer Build Version be upgraded during “Update Now”?
Hi! I think you need to go into the Test Flight app in order to upgrade the CE app, rather than using Update Now.
After posting I did go to Test Flight install. I got an update prompt. I select update. Is this the proper way to receive an a build version update. Is there away to verify what version I’m running on iOS 14.0.1?
Thanks bobseekone!!
Until Coastal Explorer is released in the App Store, Test Flight is the only way to install updates and to find out what version you currently have. Test Flight also has the option to notify you in various ways when a new Coastal Explorer update becomes available.
