Importing tracks into cloud layers
I’m just starting to experiment with cloud layers and the Android app, so this may be a user problem and not a bug, but I find:
I want to import a track from a .gpx file to a cloud layer. If I “import from device or file” while a (empty) cloud layer is active, it works fine. If I use the import button and select the gpx file, a new layer is created with the file name in the layer name. However, it shows 0 items. This is done in the CE on Win10.
If I use the coastalexplorer.net webapp and do the same with the import button,
the created layer is correct and displays. (And it also displays if I enable this new layer on the Win program.)
Is this a bug or operator error?
tnx,
tom
Thanks for info Tom. We’ll investigate. We’ll let you know what we find.
