Interface to NEMO
I just swapped to my spare computer due so issues with graphics on my other machine. I have noticed a strange behavior affecting the NEMO interface. Essentially if the computer goes to sleep, and you wake it up, the Ethernet interface both wireless and wired both work normally with other applications. In CE the NEMO is connected, you can access its web interface, and in settings it shows transmitting but no receive data. Restarting CE does not correct it. The only way to recover the NEMO interface is to restart the computer and open CE. Even if CE is not running, the computer enters the sleep mode, and CE is started, the NEMO interface does not receive data until the computer is restarted.
Tom
Tom:
We have encountered this issue with a non-marine product that we support. You need to go to Windows Power Setting, then Advance Power Settings and uncheck "power off USB to save power.
Here is a link that shows a fix: Zebra Support Community
This is a big issue with Windows and USB devices that don’t like being powered down by Windows.
Frank Burrows
Thank you Frank, I will try that.
