Moving Objects Between Layers
The documentation on layers says you can move items between layers. How do I do that? I would like to move routes and marks to a single layer.
Tom
Hi Tom. The easiest way is cut/copy/paste.
Just go to the layer you want to move items from, select what you want, then either copy or cut, depending. Switch to the layer where you want to put them and paste. The other way involves exporting and importing, but I’m a fan of cut/copy/paste.
Or for cloud-synchronized layers, use the Move to Layer option found on each item’s context menu (right-click on the item on the chart, or select the item(s) in the list and click More).
