I am sure there is an easy way to do this, but how do I remove Range/Bearing lines enmasse.
I have a few thousand now and need a way to clear them quickly and easily.
Thanks,
Thanks,
Hi Gurr,
You can fairly easily remove those by going to Layers → items (up top) → Show All Types and change that to Show Range/bearing lines. From there you can use shift to select an entire page of lines at a time to delete until finished.
Thanks!
Cadence (Cay) Denning
Support Engineer
Rose Point Navigation Systems
425-605-0985
Support@rosepoint.com
