Nearly all of the RNC charts for the Pacific Northwest were cancelled out of CE at the last update. Where did they go? Can I get them back?
Hi there,
This is part of the ongoing retirement of raster charts by NOAA, you can find more info here Coast Survey to shut down the Raster Navigational Chart Tile Service and other related services
Cay, I would like to keep the last version of the RNCs. Is there an active deletion going on and, if so, can I preserve those I have already downloaded?
You can inhibit updates:
Settings → Charts and Add Ons → NOAA RNC
Each chart group should have a choice to inhibit updates.
I found numerous charts with the notation “this chart has been cancelled”. Displaying the area with the cancelled chart, it was not showing. However, clicking “charts here” showed the missing chart listed but unchecked. Checking the chart caused it to redisplay. When C.E. is closed and reopened, it is again unchecked and needs to be rechecked to display.
Charts that are automatically installed and updated by Coastal Explorer (like the NOAA RNC and NOAA ENC) are considered “Managed Charts”. When you copy arbitrary chart files into Coastal Explorer’s Charts folder (usually “C:\Charts”), they are “Unmanaged Charts” since Coastal Explorer doesn’t know where they came from or how to update them.
Managed Charts are not deleted when they are cancelled; they are only hidden. However, since they no longer appear in the chart catalog from NOAA, they aren’t listed on the “Settings > Charts and Add-Ons” page so it can be tricky to display them again. The context (right-click) menu can be used, but only for one chart at a time and the option only lasts until you restart Coastal Explorer.
Coastal Explorer uses folder names inside of the main Charts folder to determine if charts in that folder are managed or not. If the folder name matches a known managed chart type, then those charts are managed; otherwise they are not.
So if you rename the folder called “noaa_rnc” folder inside your main Charts folder to something like “old_noaa_rnc”, those charts will be added to your portfolio as “unmanaged charts” and Coastal Explorer will stop updating them (and will not be able to tell they have been cancelled). This will let you see all of the old charts by switching the chart panel to show Raster Charts. You will also be able to see a list of these charts in “Settings > Charts and Add-Ons” in the “Unmanaged Charts” section.
Of course you should not plan or navigate using these expired charts, but they can be nice to look at sometimes.
Brad, you said: “Of course you should not plan or navigate using these expired charts, but they can be nice to look at sometimes.”
That conclusion assumes that all of the information on a raster chart is available on the NOAA ENC’s and that is simply not true. The land feature details on the NOAA ENC’s is almost completely absent. By contrast the Canadian Hydrographic Service ENC’s now show land elevations and other features that are revealed by adjusting the zoom settings on the chart. That is not the case with the NOAA ENC’s. Has there been any consideration by NOAA to add land feature details to their ENC’s?
I routinely look at land features (elevation contours, peaks) as part of my piloting during my travels, so it is important for navigation, IMO.
Jim
I agree that land features are nice to have, but unless you’re doing something very wrong it’s much harder to run into them than the features that are on up-to-date charts.
Unfortunately, adding them to the ENC does not seem to be in NOAA’s current plan.
But have you tried Hybrid Vector Chart mode in Coastal Explorer? That will show vector charts for everything in and on the water but use other data for land areas. Once you’ve enabled hybrid mode, you can choose from photo, topo, or raster charts for the land.
