Nemo is preconfigured to use DHCP to assign the IP Address.
How’s can one modify it to use a static IP address when no router is being used?
Thank you,
Mitchell
Thank you,
Mitchell
By default, the Nemo Gateway will use DHCP when possible and will fall back to Auto-IP otherwise. This makes it possible to use it without assigning a static IP address with any device that supports Auto-IP (including Windows PCs).
You can use the Nemo Gateway app, Coastal Explorer, or Rose Point ECS to switch to a static IP address. For Coastal Explorer and Rose Point ECS, open “Settings > Electronics > (your gateway) > Gateway Settings”. For the app just select your gateway from the list. One you’re on the configuration page choose “System Settings > IP Address > Edit”.
Brad,
Thank you for your kind reply to my question, providing needed info after-hours.
Rosepoint support is the best…!
Mitchell
